Hello
Try running one of the nireports examples. I tried a shared printer and it seemed to work ok.
NIReport_Print (reportHandle, "\\\\tempest\\ae04", 1);
You might want to check if your slashes are correct. You should try using "\\\\SrvProd\\HP Business 2230/2280" instead. I got the same error number when I had the incorrect number of slashes
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
