LabWindows/CVI
recovery of a result under labwindows
on a project based on image processing using vision assistant for processing under a script and then convert it to code c under labwindowscvi 2017, where I calculate distances between every 2 points on the image using (caliper) under Vision Assistant, after code generation as follows
Somewhere in the IVA_ImageProcess function, there is a call to a function similar to this:
VisionErrChk (IVA_GetDistance (image, ivaData, 2, 0, 2, 2, & caliperResults));
caliperResults is a structure of type IVA_Result whose definition is given a little higher in the file
typedef struct IVA_Result_Struct
#if defined (IVA_STORE_RESULT_NAMES)
   char resultName[256];           // Result name
#endif
   IVA_ResultType  type;           // Result type
   IVA_ResultValue resultVal;      // Result value
} IVA_Result;
The result of the measurement is in the value resultVal which can be  type : bool or double or char
So i want to calculate the distance between several points  my qst:
1 how to display the result i would like to test and see the results under  CVI
2 how to recover its data as an array to reuse it to calculate another parameters
Thanks for help
Message 1 of 1
(1,868 Views)
