LabWindows/CVI
ivi com with CVI 6.0
Can you create a IVI Com driver using CVI 6.0? If not what is the minimum rev that can do it?  Is there anything special that I need to do to my C code to do this?
(3,055 Views)
Hi sage69,
I just want to clarify that you are trying to build an IVI-COM wrapper for an IVI-C driver in CVI, correct?  If so, this is not possible.  You can however use an IVI-COM driver within CVI.
Cheers,
Kelly R.
(3,032 Views)
