LabWindows/CVI
implementation of equations on CVI 2009
Hi all,
Have anyone of you implemented the State Space Equations on Labwindows 2009?
I have no idea of implementing these equations.
Any example will be greatly appreciated.
(3,655 Views)
Greetings, are you referring to a specific CVI function or are you just wanting to set up a State Machine in general?
Product Support Engineer
(3,638 Views)
Hi James
Thanks for your reply. Basically i want to implement the attached control systems equations in CVI.
(3,631 Views)
Hmm, it seems as though this system of equations should be something you can implement in the form of a few arrays and then operating on them using for loops to perform the normal matrix operations. Does this help or is there a particular hurdle you're running into?
(3,613 Views)
Hi James,
Can you illustrate your solution with the help of an example?
(3,610 Views)
I'm afraid I don't have any examples of this handy. I'd recommend looking for resources on matrix math in C. I found a number of links that look like they might help you by searching for "C matrix math" on google.
(3,593 Views)
