Select build\target type\dynamic link library. You need a h file which you want to export. You can select that under build\target settings.
I think you also need dllmain in your main c file. Which you can insert from your c file. Edit\insert construct\dllmain.
Sheetal
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
