LabWindows/CVI
how to count number of ones in table
 i created one table 16x32 each cell is updating 1 byte of data,how to count number of one in all cell,and is it right way to calculate check sum??
thank you
(4,715 Views)
The simplest way is to call GetTableCellRangeValues with VAL_ENTIRE_TABLE as the range, next summing array elements.
But I don't understand your comment on checksum, so this may not be the more correct method for your actual needs: can you explain what do you mean?
(4,708 Views)
how to write code for check sum and size i have 16x32 table..
(4,683 Views)
Discussion on checksum follows here
(4,671 Views)
