LabWindows/CVI
how to control image file (jpg, bmp)
Hi all
Currently I have one jpg file and one bmp file.. I wanna control both of the picture.. like when the condition is TRUE it will display jpg file and hide the bmp file, if the condition is FALSE will be otherwise... THANKS!!
(3,013 Views)
If you can load both images on the UIR when you develo the application (i.e. they are not too big) you could use a picture ring control associating the values 0 (False) and 1 (True) to them according to your needs. Simply using SetCtrlVal (panel, control, 0 (or 1)) will display the right image and hide the other.
If you need to load images at run-time you can load them using InsertListItem (panel, control, index, "image_pathname", value). Again, assign 0 or 1 according to your needs.
If you prefere to have only one image loaded in memory at a time, you can use a simple picture control instead of a ring and load the desired image with DisplayImageFile command.
(3,007 Views)
