LabWindows/CVI
how can I obtain the usable height of a tab panel?
I've designed a tab page. In the UI editor I can set the height of the panel including the tab (tabs are on top). How much vertical space is left for the usable panel tab, i.e. excluding the tab - phrased differently, how high is the tab? In the UI editor I can play with tabs on top and tabs left for estimating the panel height, but can it be determined (a) in a more professional way and (b) programmatically?
Thanks!
(4,260 Views)
Not exactly a good aswer this one, but... tab height is related to the font size used for the tab with the grater font of all. In particular, tab height is 2 pixels less than the height of a button control with the same font (3 pixels if not using Windows theme for controls).
(4,255 Views)
Accepted by topic author Wolfgang
Wolfgang,
You can always get the tab panel handle programmatically, using GetPanelHandleFromTabPage, and then call GetPanelAttribute(...,ATR_HEIGHT,...). Then, you can subtract that value from the height of the tab control.
You might also have to subtract a couple of pixels for the panel frame, depending on what you'll be using the tab height for.
Luis
(4,242 Views)
Roberto and Luis,
thanks for both answers!
@Roberto: it wasn't that bad Smiley Wink Actually because it is easily possibly to determine the height of a button control in the UI editor knowing this equivalence is valuable to know!
(4,224 Views)
