LabWindows/CVI
external in and out triggers on pxi 6541
I need to use both trigger-in and trigger-out events.  It appears there is only one front panel port, i.e. SMB PFI<0>.  If I use that port for the trigger-in, what options are there to get a trigger-out signal out of the box (not pxi bus)?
(3,259 Views)
Accepted by topic author bjasper
The PXI 6541 actually has four PFI lines which can be used for importing and exporting triggers - though as you've determined, only PFI 0 has a direct front panel connection.  The others (PFI 1-3) are accessible through the Digital Data & Control port, and thus can be easily accessed when using either the CB-2162 or SMB-2163 connector block (or any similar breakout for the DDC port):
https://www.ni.com/docs/en-US/bundle/cb-2162-user-guide/resource/cb-2162-user-guide.pdf
https://www.ni.com/docs/en-US/bundle/smb-2163/resource/smb-2163.pdf
Hope this helps!
James M.  |  Applications Engineer  |  National Instruments
(3,244 Views)
