11-09-2017 07:16 AM
Dear All,
I am always getting this link error.
I suspect that the project I am trying to build was made in a previous CVI version.
Please help
Francesco
11-10-2017 01:55 AM
Hello Francesco,
try to look at the folowing documents, you'll maybe find useful information.
http://digital.ni.com/public.nsf/allkb/862567530005F09C862566200066DEF8
http://digital.ni.com/public.nsf/allkb/BF8084DB74021EE986257AB200001737
11-10-2017 03:14 AM
Thanks for your reply.
Can be a windows releted problem? one collegue has windows 7 and it seems to compile and build fine but I have windows 10.
Francesco
11-10-2017 04:15 AM
I found that ImageBase is mentioned here:
http://zone.ni.com/reference/en-XX/help/370051M-01/cvi/usermanual/prjbuildopt/
11-10-2017 05:47 AM
I have made some more experiments.
I started from the example here: http://www.ni.com/example/31151/en/
It works fine.
Then I added the .lib and .h that I need to use and added some simple code just to open an USB communication.
I get the same error I get in my project.
If I comment the line with hid_open then no problem.
I am attaching the modified example in case of need.
Francesco
11-17-2017 03:29 AM
Update: in CVI2010 the project can be successfully compiled and built. In CVI2017 not.
So maybe there is some kind of issue with 32-bit DLL managing in CVI2017.
