LabWindows/CVI
dll directory
Hy.
I have a question about dll directory.
I created application that use dll (the dll made by me) and i use it implicitly.
In order the application to work properly i can place the dll in [system32] directory under [windows] or in current (Executable) directory or in both.
In my situation the dll can be located in one of the above two folders, without my knowledge. How can i programaticly detect from with directory dll loaded?
Thank you.
Boris.
Best Regards
Boris
(3,209 Views)
Assuming that you want to know this path from within the dll. You can use GetModuleFileName (http://msdn.microsoft.com/en-us/library/windows/desktop/ms683197%28v=vs.85%29.aspx) and GetModuleHandle (http://msdn.microsoft.com/en-us/library/windows/desktop/ms683199%28v=VS.85%29.aspx). Otherwise you'd have to call this from LabVIEW itself using the call library function node.
Matt
(3,203 Views)
