LabWindows/CVI
color ramp of numeric meter or slide is missing on execution
I,m using CVI 2010 (10.0.1. (419) on windows 7 - 64 Bit.
Within a simple program i'm using a numeric meter. I'm also using the color ramp of the numeric meter and on the uir i can see the ramp as expected with the defined colors. But when i run the panel (in debug or release mode), the instrument (meter) shows up but without the color ramp.  If i save the uir-file,close it and then reopen it, the color ramp in the uir file is also missing, so i have to setup it again. It's the same with a numeric slide.
I think its a bug? Has anyone the same problem?
Greetings from bremerhaven
Norbert
(3,128 Views)
Accepted by ISITEC_RIEPER
My guess is that you have  inadvertently saved the .UIR in an old format (8.1 or older). In the UI editor, check the bottom right corner of the window to see what the current format of the .UIR is.
If that's what's happening, you'll need to change it via File>>Save As.
Luis
(3,118 Views)
Thany you Luis!
Yes the uir was saved as an 8.1 uir. I didn't even know that this is possible. Now i saved it s a 2010 uir and everything works fine.
Thanks again
Norbert
(3,110 Views)
