LabWindows/CVI
build error : "Failed to copy a distribution" after update
Hi
I have cvi 2013,
After  i made SW update  ( loacted in the help menu)  cvi filed to build any peoject.
I recive error massege ""Failed to copy a distribution"/
Please an advice
(3,609 Views)
Hi shai007,
Can you provide some more context, please:
  1. Did you upgrade from a pre-2013 version to CVI version 2013?
  2. The error message you described doesn't seem to be linked with build a CVI project (from the Build » Build), but it seems to be rather tied to creating a CVI distribution (Build » Distributions » ...). Can you confirm that you were actually trying to build a distribution? If so, does just building the project succeed (i.e. without creating a distirbution, simply press Build » Build)?
  3. If you were trying to build a distribution fails, have you verified that the target location for copying the distribution is accessible? Have you tried creating a different distribution for the same project?
- Johannes
(3,593 Views)
