10-15-2013 10:40 AM
Hello.
I need to print a serial number using the zebra printer TLP 2844. I am connected through USB because I don't have Serial port nor parallel port.
I have been able to print my serial number using the Zebra printer tools (see the screen shot for more details) with the EPL Commands :
"N
B30,0,0,1,1,20,60,N,"13.10.123456.123456"
P1"
But now, I don't know how to do to send these EPL commands inside my CVI application ?
Thanks a lot.
Yvan
10-15-2013 03:58 PM
Try by creating a plain text file with the command to be print and send it directly to the port. For example, using LPT1 you would need to write a command line like this: copy NameOfFile.ext LPT1. Try it for your COM Port.
10-16-2013 06:54 AM
Hello.
Thanks for your answer Victor.
Unfortunately, as I wrote. I don't have parallel port nor com port in my PC.
So the only way I can drive this printer is by USB....
10-16-2013 07:40 AM
You can use VISA to communicate via USB
10-16-2013 09:11 AM
Flllow the instructions in the attached link.
https://support.zebra.com/cpws/docs/usb/dos2usb.pdf
Do not forget to give some kudos.
10-16-2013 09:14 AM
Thanks a lot Victor.
It works well !!
