LabWindows/CVI
[XNET][CVI2013] Check is CAN port communication is active and check for periodic signal
I'm using CVI 2013 and the NI Automotive Diagnostic Command Set 1.1 toolkit.
Board NI PXI 8513 (2 CAN bus)
I want to know how can I check is a CAN port communication is active, and if so, how can I check if a periodic signal is currently about to be sent ?
No problem if they are two separate functions.
blue
(3,647 Views)
Hi Blue,
Instead of posting this in the LabWindows/CVI forum, post it here. Once the question is posted at the new forum, please let me know the link.
Can you let me know why you want to check the port status as well?
Ren H.
Applications Engineering
(3,618 Views)
Thank you for your reply.
I have posted the new post here
Infact I don't need to check the port status anymore. I'm just looking how to check for periodic signal on CAN.
Blue
(3,608 Views)
