11-24-2008 03:45 PM
I have a hard time to figure out why I get this runtime error so I'm asking for help. Here is the code
// DAQ DIGITAL INPUT Reserve line 23-31
char chanP1TestIn[] = "dev1/port0/line30:31"; // 30: test, 31:retest
/////////////////// Digital Inputs //////////////////
DAQmxErrChk (DAQmxCreateTask("",&P1TaskDI));
DAQmxErrChk (DAQmxCreateDIChan(P1TaskDI,chanP1TestIn,"P1Test",DAQmx_Val_ChanForAllLines));
DAQmxErrChk(DAQmxSetChanAttribute(P1TaskDI, "P1Test", DAQmx_DI_InvertLines, 0));
DAQmxReadDigitalU32(P1TaskAI,1,timeOut,DAQmx_Val_GroupByChannel,&data,1,&read,NULL);
I've changed to DAQmxReadDigitalLines format and still have the same error code. LabWindowsCVI 8.5 with DAQ PCI-6629
NON-FATAL RUN-TIME ERROR: "AntiG.c", line 1156, col 21, thread id 0x00000F7C: Function DAQmxReadDigitalU32: (return value == -200525 [0xfffcf0b3]). Measurements: Read cannot be performed because this version of DAQmx Read does not match the type of channels in the task. Use the version of DAQmx Read that corresponds to the channel type. Task Name: _unnamedTask<4> Status Code: -200525
Lanny
11-24-2008 03:49 PM
