LabWindows/CVI
Where can i find DataSocketCore.msm 4.7 or higher
we use the DataSocketCore.msm which contains the data socket in the version 4.6.
Because we found a bug which has been fixed in the version 4,7, we want to exchange the merged module with a newer one.
But i am not able to find the merged module in a higher version. Only the msi packages.
Does the merged module stil exists or do we have to deploy the msi installer?
Thanks for any help.
(4,825 Views)
which CVI version do you use and miss the msm file?
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(4,802 Views)
I use LabWindows CVI 2013 SP2. This installation does not contain the DataSocketCore.msm
(4,799 Views)
HI,
you have to use the .msi packages. The .msm files do not exist seperatly any longer.
annav
Anna Vogl
(4,781 Views)
Accepted by K.Werner
I found the DataSocketCore.msm version 4.8 in the measurement studio 2015 installation.
The dependendy OPCenum.msm contains a bug that i fixed manually but it works. So this msm seems to be the last version of the DataSocketCore.msm, right?
(4,778 Views)
