When compiling the project, I get an "An internal error has occurred in the compiler" message.
I set "Debugging level" to "No run-time checking" in "Build Options", but the same error occurs.
As for the development environment, "CVI" uses version 2017(Version 17.0.0 (295)), and the operating system uses "Windows10".
I would appreciate it if you could check it out and explain the solution.
