Even if you solve this, you will run into problems if the user clicks on
menu as then the processing also stops.
You better off creating a separate thread to do your measurement. I didn't
use threads earlier but now after using them, its hard to go back.
vishi
"Babak.pourat"
wrote in message
news:3e8a9bbe@newsgroups....
> Hello,
> we have a measument routine whitch takes some seconds. To process user
> input, a "ProcessSystemEvents()" is called at about all 200msec. All
works
> fine.
> But if the the mouse curser stays over the menu bar the routine seems to
be
> blocked.
> What is the reason for this behavior, an is there a solotion to increase
the
> processing speed?
> Thanks
> Babak Pourat
