LabWindows/CVI
Use vb.net dll from LabWindows/CVI 8.5 causes error
Dear Sir/Madam,
I have encountered a problem when assembling .NET library using LabWindows/CVI 8.5 version.
Problem Encountered:
1. "Maximum number of function tree nodes exceeded" when CVI is browsing assembly and generating wrapper code.
2. "Maximum number of lines exceeded" when compiling source.
Scenario: We are trying to create a .NET controller (VB.NET DLL) so that we can use the VB.NET library in our LABWindows/CVI program. The file VB.NET.dll file only has 620KB in size. However when we try to create a .net controller (.fp too) Labwindows prompts the 2 messages above. It fails to create the .fp and .c because of the problem caused as mentioned above.
How should we fix the problem?
Hope you can help us.
Ryan
Message 1 of 1
(3,072 Views)
