LabWindows/CVI
Timer events prevent Windows minimisation
Is there any way to prevent Timer events from causing the CVI app to be restored when the application has been minimised?
I am using timer events to regularly check for activity on a serial port. I guess the obvious solution is to install a comms callback to do this but I wondered if there is another solution if for example I was not using a serial port yet still wanted to do some task at regular intervals even when application is minimised.
(3,084 Views)
I have not seen this before. Try using the timer sample under ..\samples\userint called timer. It uses a UI timer andI didnt have problems minimizing it.
Bilal Durrani
NI
(3,077 Views)
Problem solved - it wasn't the timer event after all. In the associated callback I called SetActivePanel() and that was the problem
(3,065 Views)
