LabWindows/CVI
Thread id 5232: Argument must be an open stream error
I made code which writes in txt file my array, but when I want to read file I get this error:
FATAL RUN-TIME ERROR: "Programa.c", line 99, col 21, thread id 5232: Argument must be an open stream.
My code:
#include <formatio.h>
#include <utility.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "Programa.h"
// Globalus kintamieji
static int panelHandle, panelHandle2, panelHandle3;
FILE *fp; // deklaruojamas failo pointeris
int kiek = 0;
// Funkcijos
void Registravimo_funkcija(void);
void Antrastes_kurimas(void);
int main (int argc, char *argv[])
	if (InitCVIRTE (0, argv, 0) == 0)
		return -1;	/* out of memory */
	if ((panelHandle = LoadPanel (0, "Programa.uir", PANEL)) < 0)
		return -1;
	if ((panelHandle2 = LoadPanel (0, "Programa.uir", PANEL_2)) < 0)
		return -1;
	if ((panelHandle3 = LoadPanel (0, "Programa.uir", PANEL_3)) < 0)
		return -1;
	SetActivePanel (panelHandle);	// Nustatomas pagrindinis langas kaip active
	DisplayPanel (panelHandle);		// Isvedamas interface 1
	RunUserInterface ();
	DiscardPanel (panelHandle);
	DiscardPanel (panelHandle2);
	DiscardPanel (panelHandle3);
	return 0;
int CVICALLBACK Registravimo_pradzia (int panel, int control, int event,
									  void *callbackData, int eventData1, int eventData2)
	switch (event)
		case EVENT_COMMIT:
			DisplayPanel (panelHandle2);	// Isvedamas darbuotojo registravimo langas
			break;
	return 0;
int CVICALLBACK Registravimo_pabaiga (int panel, int control, int event,
	switch (event)
		case EVENT_COMMIT:
			Registravimo_funkcija();
			HidePanel (panelHandle2);		// Uzdaromas darbuotojo registravimo langas
			//Registravimo_funkcija();		// Funkcija sukurianti nauja vartotoja
			break;
	return 0;
int CVICALLBACK Exit (int panel, int control, int event,
	switch (event)
		case EVENT_COMMIT:
			QuitUserInterface (0);
			break;
	return 0;
int CVICALLBACK Vartotojo_sasaja (int panel, int control, int event,
	switch (event)
		case EVENT_COMMIT:
			DisplayPanel (panelHandle3);
			fp = OpenFile ("filename.txt", VAL_READ_WRITE, VAL_APPEND, VAL_ASCII);
			char ReadArray[300];
			//ReadFile (fp, ReadArray, 200);
			FileToArray ("filename.txt", ReadArray, VAL_CHAR, 300, 3, VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_ROWS, VAL_ASCII);
			/*int c;
			if (fp) {
    			while ((c = getc(fp)) != EOF)
        			putchar(c)*/
			fclose (fp);
			char line [256];
			//fp = fopen ("TextFile.txt", "rt");
			while (fgets (line, 256, fp))
    			InsertTextBoxLine(panelHandle3, PANEL_3_TEXTBOX, -1, line);
			//FileToArray ("filename.txt", ReadArray, VAL_CHAR, 300, 1, VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_ROWS, VAL_ASCII);
			//ReadLine (fp, ReadArray, 200);
			//InsertTextBoxLine(panelHandle3,PANEL_3_TEXTBOX,-1,ReadArray);
			break;
	return 0;
int CVICALLBACK Isjungti_darbuotoju_stebejima (int panel, int control, int event,
	switch (event)
		case EVENT_COMMIT:
			HidePanel (panelHandle3);		// Uzdaromas darbuotojo registravimo langas
			break;
	return 0;
	//** Registravimo funkcijos kintamieji
	char IDmasyvas[9];					// ID masyvas
	char NAMEmasyvas[17];				// Vardo masyvas
	char SURNAMEmasyvas[17];			// Pavardes masyvas
	char POSITIONmasyvas[19];			// Pareigu masyvas
	char WORKINGOURSmasyvas[17];		// Darbo valandu masyvas
	//char SENDarray[81];					// Vartotojo masyvas
	char Filearray[200];
	int menuo, diena, metai;			// Isiregistravimo i darba datos kintamieji
	int itemIndex;						// Ring kintamuju indekso kintamasis
	//** Reiksmiu nuskaitymas
	GetCtrlVal (panelHandle2, PANEL_2_ID, IDmasyvas);				// Nuskaitomas ID
	GetCtrlVal (panelHandle2, PANEL_2_NAME, NAMEmasyvas);			// Nuskaitomas Vardas
	GetCtrlVal (panelHandle2, PANEL_2_SURNAME, SURNAMEmasyvas);		// Nuskaitoma Pavardė
	//** Ring reiksmiu nuskaitymas
	GetCtrlIndex (panelHandle2, PANEL_2_POSITION, &itemIndex);			// Skiriamu pareigu kintamojo indekso nuskaitymas
	GetLabelFromIndex (panelHandle2, PANEL_2_POSITION, itemIndex, POSITIONmasyvas);				// Nuskaitomos Skiriamos pareigos
	GetCtrlIndex (panelHandle2, PANEL_2_WORKINGOURS, &itemIndex);		// Darbo valandu kintamojo indekso nuskaitymas
	GetLabelFromIndex (panelHandle2, PANEL_2_WORKINGOURS, itemIndex, WORKINGOURSmasyvas);		// Nuskaitomos Darbo valandos
	//** I sukurta masyva itraukiama raide R, kad procesorius suprastu, kad norime sukurti nauja vartotoja
	//sprintf(SENDarray,"R%15s%16s%16s%16s%16s",IDmasyvas, NAMEmasyvas, SURNAMEmasyvas, POSITIONmasyvas,WORKINGOURSmasyvas);
	//** Siuntimas i MCU
	//** Duomenu irasymas i .txt faila
	fp = OpenFile ("filename.txt", VAL_WRITE_ONLY, VAL_APPEND, VAL_ASCII);		// Atidaromas failas
	if (kiek == 0)
		Antrastes_kurimas();
	kiek = kiek + 1;
	sprintf(Filearray, " %3d     %8s      %13s      %15s       %19s      %13s", kiek,  IDmasyvas, NAMEmasyvas, SURNAMEmasyvas, POSITIONmasyvas, WORKINGOURSmasyvas);
	//InsertTextBoxLine(panelHandle,PANEL_TEXTBOX,-1,Filearray);
	WriteLine (fp, Filearray, -1);
	CloseFile (fp);
	// Masyvas antrastes
	char Masyvas[200] = {"  #         ID            Vardas              Pavardė                Pareigos           Darbo valandos  Išdirbta valandų  Pavėluota į darbą  Išeita per anksti "};
	WriteLine (fp, Masyvas, -1);			// Rasomas masyvas i faila
(2,485 Views)
Accepted by topic author AsRycka
Hi, there is a lot to say about your code!
Let's start from Registravimo_funkcija () function that writes the fie. You declare a global file handle of type FILE * but you are using functions from the Formatting and I/O library that expect a file handle of type int (as you can read in the function help!). You should have found several errors and warnings in compilation, I tend to say that this code could hardly run and if run would probably generate garbage if not nothing at all. But since you are generating as ASCII file you can examine it with notepad and see the result. As a last hint, there is no need to use a global variable for that since you do not need to share the file handle across multiple functions.
Coming to Vartotojo_sasaja () function tat should read the file, FileToArray () function does not need the file to be open before: it opens and closes the file by itself. Furthermore, the function expects the file contains data of the same type, but you are writing lines mixed with numerics and texts so the function cannot interpret it correctly.
Finally, you haven't put any error checking in your code! I strongly suggest you to implement a robust error checking method in all functions that perform I/O operations so that every abnormal situation found will be detected for you to correct it.
(2,448 Views)
