01-19-2012 07:43 AM
That was the problem! Thank you.
I used the version number to determine if the files "matched", and I did not restart CVI before testing each of the revision files. I should have known better, but that step is left out of the step by step instructions. It would also be helpful if they made it clear that the file will not necessarily be an exact match, since the version doesn't necessarily match.
Great Job, Thank you very much!
01-19-2012 10:28 AM
Great. Glad to hear it! I've left feedback on that Knowledge Base based on the ambiguities you ran into. Hopefully it will be updated for the next person that needs to follow it.
Mert A.
