LabWindows/CVI
Some problems occured when using "OpenFile" , "ReadFile",could someone help me please?
FILE  *Pow_filehandle = NULL;
int  nRead = 0;
Pow_filehandle = OpenFile ("Power_TestLowData.txt", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_BINARY);
if (Pow_filehandle == NULL)
  MessagePopup("","文件打开失败!");
 nRead = ReadFile (Pow_filehandle, buf, strlen(buf));
when i compiled it ,some errors like these occurs:
 DataAcq_posia.c - 8 errors
  322, 57   Undeclared identifier 'VAL_READ_ONLY'.
  322, 70   Type error in argument 2 to `OpenFile'; found 'int' expected 'LPOFSTRUCT'.
  322, 72   Undeclared identifier 'VAL_OPEN_AS_IS'.
  322, 88   Undeclared identifier 'VAL_BINARY'.
  322, 98   Too many arguments to `OpenFile'.
  322, 99   Operands of = have illegal types 'pointer to FILE' and 'HFILE'.
  328, 54   Type error in argument 1 to `strlen'; found 'pointer to unsigned short' expected 'pointer to const char'.
  328, 56   Insufficient number of arguments to `ReadFile'.
Is there someboy can help me ?Thanks.
Regards!
(4,660 Views)
Accepted by 宝宝熊
it seems as if you have mixed up some instructions in your code...
OpenFile () is a command from the Formatting And I/O Library of CVI; it returns a integer handle. The FILE * pointer is returned from fopen () command from standard C library.
So you should decide which library are you intending to use and match the file handles to that.
I'm a little puzzled about the "Undeclared identified" errors: they should already be in your list of include files, or CVI should have prompted you to add the proper #include file when launching the application (BTW, it is formatio.h): which version of CVI are you using?
(4,652 Views)
Some comments about  your code:
/* The FILE * type is used by ANSI C file functions and not by the NI formatio library specific file functions, which use a filehandle of type int */
int  nRead = 0;
/*To get the prototype for  OpenFile()  and the declarations for VAL_READ_ONLY etc  , you have to #include <formatio.h>
and there is also a Windows SDK function named OpenFile() which you get if you #include <windows.h>.  You can't mix up NI's formatio library and the windows SDK */
// error condition for the filehandle is the value -1
// There is also a windows SDK function named ReadFile()
(4,649 Views)
Roberto?
Hi,thanks for your help. The version Which i am using is CVI 8.0.
posia
(4,632 Views)
markus kossmann ,
Thanks  very much for your reply.
posia
(4,629 Views)
