12-15-2022 10:00 AM
So, if I interpret the profiler correctly, my software really does practically nothing on this test setup. I use the profiler for the first time though, so I don't exactly know how to use it. I have added CVIProfSetCurrentThreadProfiling(1); at the start of every thread (WinMain aswell) and that's it.
This is the only thing that thImageSaver did (apart from some init things at the start):
And this is was WinMain mostly did (apart from some init things at the start):
Again, I merely started the application up, let it do its startup things and then moved the mouse around for about 5-10 minutes until the performance dropped.
The 2020 runtime seemingly prevents this issue, unless it only happens after a lot of hours, which I haven't tested yet.
12-15-2022 10:03 AM
@gdargaud wrote:
It's not just a licensing problem, it's a linking problem. Function signatures may not match and it'll either refuse to run outright (if you use InitCVIRTE) or will crash when calling certain functions.
I use InitCVIRTE and also there was a question about RTE backwards compatibility on this forum:
To add clarity: I am developing using CVI 2017, the runtime where the application starts to slow down is 2017, the runtime where it does not is 2020.
12-16-2022 06:48 PM
AFAIK there are no licensing problems in installing whichever runtime version you want to. And I have never find any issue till now in running an application with a RTE more recent than the IDE the application was compiled into.
