01-12-2015 02:53 PM
Hi Guys,
I'm new to the forum, so i appologize for the rule breaking (if there's any) and my bad english.
For one of my classes i decided to create the "Simon Say's - Memory Game" as my final project.
We using CVI/LabWindows 2012, just to be clear about it.
The problem i'm experiencing is that I can read from the array of colors i created.
I have a main panel where the start playing button located, after i press it the playing panel is poped up and and array of 150 integers is create with numbers between 1-4 (every number is associated to different command button) . The commnad button are initialy are dimmed, and there 4 command buttons (4 different colors).
What I need to do is to read from the array X amount variables, and using a switch to decide what button "blink".
I've tried using a timer/loops and every other thing I could think of (it's very basic course, so no crazy functions) and have nothing to show for.
Can't figure out how to read a variable from array in Y spot and make it blink ( commnad button goes from dimmed to undimmed-waits for some time-becomes dimmed again) and then read X+1 variables from array and display them in the some order on the screen using the dimmed/undimmed.
Every coment will be appreciated.
Thanks in advance!
01-13-2015 05:04 PM
Hi Slavik87,
It is a bit unclear as to what your main question is, could you clarify about the exact problem you are having?
