10-20-2017 02:27 AM
i'm new in LABVIEW and I want to use a Burster 8661 Torque-Sensor, which is connected via USB. I installed the LabWindows-Drivers via the Labview Instrument Driver Import Wizard. I followed the Instructions in the Manual of Burster.
I made a Little Labview-Program, that should read the Serial Number and the Torque. The Serial Number is detected and shown correctly. So I guess, that the Driver is installed correctly ?
The Torque jumps between 0 and -0, depending on the turn-direction of the measurement-shaft, but does not Show the real Torque-Value.
Can anybody help me or had a similar Problem?
Thanks for your help!
Kind regards
Steffen
10-20-2017 06:19 AM - edited 10-20-2017 06:20 AM
Steffen, it's not clear to me whether you are programming in CVI or LabView!
Just a guess: could it be that your sensor has a less-than-1Nm range? If so you could read the correct value simply adding some digits of precision to your indicator.
If not, taking a look at your code may help to understand what's happening: if you are working in CVI you may post it here, otherwise you should repost this entire question to the LabView board, possibly adding your VI
10-23-2017 12:08 AM
thank you for your fast answer. I am programming in LabView using Labview 2016. I will check if i can add some Digits of precision. I used the Labview Labwindows Import wizard, which is why is used (probably falsely) this Forum and I will add this Topic to the LabView Forum... Thank you!
10-23-2017 08:25 AM
Discussion follows here in the LabVIEW board
