LabWindows/CVI
Setup Standard IO and DLLs
This isn't really a big problem, but something that I'm curious about.
I use TestStand with CVI DLLs. I like to use the standard io window to show the operators data during a long test.
Can someone please explain to me why
these call won't work in a DLL
//SetStdioWindowVisibility (1);
 //SetStdioWindowPosition (740, 40 );
 //SetStdioWindowSize(240, 800);
but this one does.
 SetStdioWindowOptions (10000, 0, 400);
Just wondering
Curt
(2,016 Views)
Hi!
Only for double checking, which version of TestStand and CVI are you running?
Any particular step to reproduce it?
(1,986 Views)
Thanks for the reply.
I'm using TestStand and LabWindows 2012
Here's the function called from TestStand.
The first 3 functions return error -3.
"This function can be called only from the main thread of your program ".
As I stated in the previous post, it's not a big deal but it doesn't make any sense why the set  options function works and the others throw an error
void __declspec(dllexport) setupStandardIO(CAObjHandle seqContextCVI,
        char reportText[1024], short *errorOccurred, long *errorCode, char errorMsg[1024])
	sprintf (reportText, "Setup Standard IO Window");
    logMessage(LOGFILENAME,"%s\n", reportText);
	//these functions don't work in a dll!
	SetStdioWindowOptions (10000, 0, 400); //max 10000 lines, 0 = bring to front off, show 400 lines
	return;
Curt
(1,962 Views)
Thanks for the steps,
Let me try to set up everything.
Curt.
(1,952 Views)
