02-05-2019 04:04 AM - edited 02-05-2019 04:09 AM
I am new to LabCVI. I have Sorensen DLM 60-10 power supply. I have communicated with instrument through VISA interactive control and now I would like to communicate using function panel of IVI driver. While configuring that I have used different possibilities of giving Resource Name but it shows error. To find the correct resource name I have enabled the "Extended" Debugging level in build option also. I could not find the correct resource name. Can any one help me out!
Thanks.
Solved! Go to Solution.
02-05-2019 04:36 AM
It looks like you are missing the ".." around the resource string.
It should look like "GPIB0::1::ADDR".
Hope this helps..
02-05-2019 05:28 AM
Its works,
Thank you!
