I have an application that needs to read in a set-length string of 13 data readings seperated by a commas. I have a vi set up that will take the incoming string and seperate it out to its different data points. BUT, when I'm reading in the data over the serial port, I don't know how to wait until I have a complete set of 13 data points before displaying my data. I'm using a vi that extracts doubles from the string to display all 13 data points, and as each point is recieved from my test item, it scrolls through the 13 seperate data displays.
Basically, I need advice on how to read in a full string of 13 data points and after the full string is read in, then display them using an extract_from_string vi.
Thanks in advance
jimmy
