LabWindows/CVI
Permanently exclude NI/LabWindows CVI Shared Runtime from Distribution Kit
Since it's already installed on the deployment PC, I want to remove NI/LabWindows CVI Shared Runtime from Distribution Kit.
For this reason I un-checked it from "Drivers & Components" tab.
I never found which is the root cause, but sometimes I find it enabled-back.
And so every time I need to rebuild the  Distribution Kit I must go to Build >> Distributions >> Edit xxxx and verify it's un-checked.
Really annoying...
Is there a way to permanently disable it?
So that it's never re-added automatically?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(1,480 Views)
Hi vix,
Did you try to update your CVI version? Try to update that because in my side everything is okay and it should be solved by updating version.
I am using LABWINDOWS/CVI 2020.
Regards 🙂
(1,312 Views)
