LabWindows/CVI
PasswordCtrl_ConvertFromString error -46
Highlighted
I'm following the example password project "pwsample.cws".  I think I've followed it, and yet when I convert my text box like this:
passCtrlID = PasswordCtrl_ConvertFromString(passPanel,PASSWORD_COMMAND);
passCtrlID is getting a value of -46 (The attribute passed is invalid.)  I can't figure out why that is.  When I step through the pwsample project, the value passed is 2.  What is going on?
(1,769 Views)
Highlighted
Accepted by topic author ElectroLund
Just to be sure it's not a typo: "text box" or "string control"? The control to convert must be a string: if you pass a different control you're likely to get an error.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(1,766 Views)
Highlighted
Eureka!  That was my problem, the control I was using (actually, I inherited this design, so it's not my fault!) was a single-line text box.  No wonder!  Changed it to a text string control and it works just fine.
(1,763 Views)
