O an going to use PXIe - 8240 via Labwindows / Cvi. But I could not find the way. Especially, which driver requires. I can see at the Max but could not see the test panel.
Thank you for repply and interest. Actually, I download this driver and I can see the module at NI MAX, but I can not see the test panel. I think there is no test panel feature.
I do not understand especially which driver requeire to Labwindows/CVI. For example, NI-DAQmx, NI IMAQdx etc.
By the way, I have studied before these documents and I do not understand.
I check out this document for five or six times, but I have still no idea how I configured via Labwindows/Cvi . For instance which command or library to initiliaze the device.
