01-24-2006 07:00 AM
01-25-2006 05:00 PM
Thank you for contacting National Instruments.
If I understand your question correctly, you are trying to configure your PXI-4461 as an analog output and the PXI-4472 as an analog input.
If you are interested in using LabVIEW or CVI for this, we have several examples available on the NI Example Finder under Help>>Find Examples. Once the NI Example Finder browse to Hardware Input and Output>>DAQmx>>Synchronization>>Multi-Device. The first example called Multi-Device Sync-AI and AO-Shared Timebase & Trig-DSA, illustrates continuous analog input and output operations. It configures a total of four tasks on two PXI Dynamic Signal Acquistion (DSA) devices. Each device runs a task for analog input and another for analog output.
We have other examples available through the NI-Developer Zone: Example Code that allows you to search for other examples.
Hope this can help you get started.
Good luck,
Tica T
Applications Engineer
01-26-2006 08:16 AM
Hi Tica,
Thanks for your response. I want to use the PXI-4461 for both input & output and the PXI-4472 channels for input.
Can the input channels & output channel specify as:
"Dev1/ai0:7,Dev2:ai0:1" input channel for PXI-4472 (Dev1) and PXI-4461 (Dev2)
"Dev2/ao0" output channel for PXI-4461(Dev2)
How do I synch them for acquisition. Do I need to create one input taskhandle and one output task handle or two input task handle and one output task handle?
Thanks again.
01-26-2006 03:59 PM
Yes, you can have an input task that handles two different boards by specifying the physical channels as: “PXI1Slot2/ai0:1,PXI1Slot3/ai0:5” where slot 2 has the PXI-4472 and slot 3 has the PXI-4461 or like you specified with Dev1/ai0 if that is the name of your board in MAX.
I have included an example that shows you how to do synchronization by using property nodes.
Hope this helps,
Tica
