LabWindows/CVI
PCI 461 PFI Input trigger to generate software event
My system has a PCI4661 DAQ and an PCI1588 sync'd to PTP. I have CVI 2015 anD NI Sync 16. I also have other network devices set to PTP.
My appliation requires all devices 4461 AO/AI and network devices to trigger and I am sucessfully using the 1588 to trigger my 4461 future timed event. The trigger is generated over RTSI.
I also need to respond to an external trigger edge and I am trying to connect an application callback to one of the PFI terminals (either 4461 or 1588). From the callback I can get the timestamp of the edge and then create a future event to start all devices triggering.
I have done quite a bit of reading around can not find a way to use a PFI to generate a software event. I understand that PFI does not provide fulls buffered operation but I simply need one way or another to get a software event.
Does anybody have any ideas to how to get an event ?
Thank you in advance, the support from this forum is invaluable.
Steve
(3,608 Views)
Update: The 1588 user manual has a section on "Using Front Panel PFI Lines as Inputs"
This hints that what I am trying to do is possible and refers to the Ni Sync User Manual for more information, but this is where the trail stops.
(3,588 Views)
Hopefully, this knowledge based article will help.
http://zone.ni.com/reference/en-XX/help/373629B-01/nisynclv/nisync_create_future_time_event/
Alex
(3,573 Views)
Hi Alex.
Thanks for the reply (I was out all christmas). I have had a look at the kb article and this describes the future time event to generate an output (or am I missing something?). I am looking to use a PFI as an input to call a software callback. Are you saying that the PFI signals can only be used as outputs?
Steve
(3,525 Views)
Further update:
I have found that I can use a timestamp to wait for a edge event to occur on a PFI input. The niSync_ReadTimeStampTrigger has got a timeout. My code now spawns off a task that runs the following code
void NiSyncExternalTrigger(char* terminal, int32_t timeout)
    NiSyncTime_t triggerTime;
    int32_t status;
    NiSyncTimeInit(&triggerTime);
    status = niSync_EnableTimeStampTrigger(session665x, terminal, NISYNC_VAL_UPDATE_EDGE_RISING);
    CheckError(status);
status = niSync_ReadTriggerTimeStamp(session665x, terminal, timeout, &triggerTime.Seconds, &triggerTime.NanoSeconds, &triggerTime.FractionalNanoSeconds, &edge);
 This can then send an event back into my event processing and send my trigger to all other systems.
 The key was finding that the nisync_ReadTriggerTimeStamp had a timeout and would wait until either an edge was detected on the PFI, or the timeout expired.
I need to do some further investigation to see if I can route PFI to the RTSI bus and still get the timestamp event.
(3,485 Views)
