04-12-2012 11:49 AM
When I open the software I get a "440 Error: The master timed out when trying to communicate with the card."
It worked yesterday, PC was shut down normally, powered up today, and ... this 440 error thing keeps happening.
I've tried all sorts of reboot, external cable disconnects, and various changes with the device manager settings.
Anyone have a clue?
04-13-2012 05:52 PM
Hi Roger,
Can you give a few more details about the software environment that you are using? You mention that when the software is opened you receive an error message, but what is the software that is being used?
In addition, can you attach a screenshot of the error message that you are receiving?
Best,
04-16-2012 03:53 PM
The software is part of our TMS 9155C test station. It was designed in NI LabWindows/CVI and uses NI SQL Driver Runtime library.
I couldn't attach a screenshot, the system is off-network but they are the standard WinXP "Error" windows.
"440 Error" in the header and the other messages in the gray body of the window.
04-17-2012 05:45 PM
Hi Roger,
It sounds like a common source of one type of 440 error is a problem with Automation (ActiveX) components used by the application. This error can occur if the application is trying to reference an ActiveX .dll that is not registered correctly on the machine. You may want to try reinstalling drivers or toolkits used by the application or if the .dll in question is pin-pointed you can try to register the .dll manually using the regsvr32 application.
