LabWindows/CVI
Overriding confirm dialog while saving an Excel file
I am writing an application that exports data to an Excel sheet by means of excel2000 instrument.I want to be able to suppress confirmation dialog box while saving a file over an existing one. The background is that the filename is choosen by the operator with FileSelectPopupEx, so if the file already exists the function automatically asks for a confirmation before exiting so an additional same dialog is annoying.
Based on this MSDN page, I experimented with ConflictResolution parameter in Excel_WorkbookSaveAs to no avail: the line I am using is this one but it keeps prompting me a confirmation dialog if the file already exists:
	errChk (Excel_WorkbookSaveAs (ExcelWorkbookHandle, NULL, MyVariant, CA_DEFAULT_VAL,
				CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
				ExcelConst_xlNoChange, CA_VariantInt (ExcelConst_xlLocalSessionChanges),
				CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL));
Based on this post by kirkm I found that calling
	errChk (Excel_SetProperty (ExcelAppHandle, NULL, Excel_AppDisplayAlerts, CAVT_BOOL, VFALSE));
I can suppress the dialog, but it suppresses all alerts that could be raised and it seems excessive to me. I wonder if anyone succeeded in hiding the dialog in Save As call.
(4,867 Views)
Well, the solution proposed there is simply to hide alerts before saving, so no way to have the parameter of Excel_WorkbookSaveAs working as it is supposed (?) to do. Hiding the alerts prevents messages despite the content of ConflictResolution parameter.
(4,820 Views)
Did you try it ?
(4,806 Views)
Of course I did!
(4,802 Views)
