LabWindows/CVI
Ni 9204
I am reaching out because I am unable to get my NI-9204 module working when connected to a cDAQ-9181. In NI MAX, I can see my DAQ, but it shows the message “unsupported module.” These modules are supposed to be compatible. LabWindows and NI-DAQmx are both version 20.0. I am new to data acquisition methods and this is my first time using NI hardware.
Could you please help me?
Thank you in advance.
(457 Views)
I have the same problem. What is the minimum LabVIEW or NI-RIO version required for this module?
I found this table
https://www.ni.com/de/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
and the module specs
https://www.ni.com/docs/de-DE/bundle/ni-9204-specs/page/specs.html
but I can't see any software version numbers there.
(288 Views)
Ok, right after posting my question i finally found this page:
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
Minimum: LabVIEW 2021 and NI CompactRIO 24.8.
(281 Views)
