LabWindows/CVI
NIDAQmx I/O Controls functions
I don't understand how the function NIDAQmx_GetDeviceCtrlAttribute() and NIDAQmx_SetDeviceCtrlAttribute() work with NIDAQmx_IOCtrl_Target attribute.
The help says it is the target name, so I think these two functions should simulate the selection of a board from the NIDAQmx Device Control (Custom Controls >> NI-DAQmx IO Controls >> Device) and should return the selected device.
But they don't work in this way.
  • The Get() function always returns an empty string (but a simple GetCtrlAttribute() returns the selected device)
  • The Set() function fails with "error -10006 Cannot read from target. Check target and connection."
See attached example that shows what I mean.
What does exactly mean the NIDAQmx_IOCtrl_Target attribute?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,076 Views)
Dear all,
NIDAQmx_IOCtrl_Target is a sort of description field, set only with the proper NIDAQmx_SetDeviceCtrlAttribute(). Without setting manually this property, the value returned by NIDAQmx_GetDeviceCtrlAttribute() is always an empty string.
Andrea R.
(3,017 Views)
