10-11-2007 11:02 AM
10-11-2007 12:43 PM
10-18-2007 06:52 AM
10-18-2007 09:15 AM
10-18-2007 09:25 AM
10-18-2007 09:51 AM
Hi Oliveira,
Back in Measurement Studio 6.0, that merge modules directory didn't exist and
so you had to use the CD to get the MSMs. Thus since you mentioned that you
didn't have that MSM, I thought you had Measurement Studio 6.0 installed.
However, you now said you have Measurement Studio 8.1.1 and when you install
C++ support, it should install all those merge modules into the directory I
mentioned.
Now my fear is that you just installed the .NET support for 8.1.1 and not the
C++ and maybe at some point you installed Measurement Studio 6.0. If this was
the case, this should explain the state you are in. Now, I don't know if you
got the Standard, Professional or Enterprise package and that would help some.
The reason for that information is because with Pro and Enterprise, you get 2
CDs, one for Visual Studio .NET 2003/2005 and on that says Measurement Studio
Support for Visual Studio 6.0. That second CD would have had that Redist
directory.
The quick fix is to just re-run the 8.1.1 installer and make sure C++ support
is enable which will copy those merge modules to the Common Files\Merge Modules
directory.
Hope this helps!
Best Regards,
