11-10-2011 11:02 AM
I'm trying to figure out how to create a message popup that also has a picture in it. I'm using TS 3.1 as my sequence editor, and this version doesn't provide this feature (I know 4.0 and later do). Has anyone done this?
11-11-2011 05:05 PM
Could you create your own UIR file that you call instead of using the MessagePopup command? This would give you complete customization control over the panel.
Sean
11-14-2011 11:27 AM
As Sean said, the easiest way is to create your own panel and use it as a popup. The new panel can be in the same UIR file as the parent panel. You can also display the new panel as a modal popup using the the LoadPanel InstallPopup function. Don't forget to create a callback for the panel (or a control on the panel) that handles the close event. You will want to call RemovePopup or DiscardPanel to close the popup.
