LabWindows/CVI
LocalizeMenuBar with chinese characters
I'm trying use "LocalizeMenuBar" function with “*.lwl” file that contain Chinese characters, the function returns -6000.
I'm actually working with CVI 9.1.0, I know that Unicode is actually not supported, did you know when CVI "LocalizeMenuBar" function will support Chinese characters ?
Thanks.
(2,916 Views)
You should be able to that - just not with Unicode. Did you paste Unicode into the localization tool? Can you load the LWL file back into the Localization Tool?  I presume you have seen this page?
For the record, I have been able to paste in multi-byte strings and have them appear correctly when it runs on a Chinese version of Windows. (On my English machine it shows a garbled multi-byte string)
Here is a way to handle the encoding, given Chinese strings provided in a Word document.  When I "Save As" a .txt file in Word it prompts for the encoding to use:
That gives me a txt file, with the multibyte encoding that I specified.
Not sure if this solves your problem, but I hope it helps.
--Ian
(2,905 Views)
