LabWindows/CVI
Labwindows UI control extremly slow (Windows10)
Recently, I installed Labwindows 2017 on Windows 10.
I used same code with Labwindows 2014/Win XP and no problem of UI(Button and any) control during debug/batch file running.
However, with Windows 10 enviroment, everytime when I start my application, when i try to push button or any UI control, i have to wait long time(approximately 10 sec for every action).
Is ther anyone who has solution about this problem?
(2,607 Views)
Hello Kimnerv01,
Could this possibly be a CPU issue? One user mentioned that it was because of a virus scanner that they had in the background unknowingly:
https://forums.ni.com/t5/LabWindows-CVI/CVI-became-unworkable/m-p/3765809
One question, to make sure that I understand this correctly. Can you confirm if the exact same code you used in Labwindows 2014/Win XP has a lagging issue when running in Labwindows 2017/Windows 10?
I look forward to hearing from you.
Vincent
(2,578 Views)
