09-03-2009 02:50 PM
I have created an OPC server using Network Variables. I can successfully use a third party OPC client to connect to the server and see the variable values on the same computer. When I launch the OPC client on a remote computer I see the OPC server, but I can't see the variables.
Do I need to have the Variable Engine service running on the remote client? If so, I thought I would get the Variable Engine service by installing the LabWindows/CVI RTE, but it was not installed.
These are both Windows XP SP2 systems and I have gone through the DCOM configuration and Firewall settings and all should be set properly.
Thank you,
Bob
09-04-2009 03:17 PM
Hi Bob,
What are you using toview the OPC server on a remote client?
Flash
09-04-2009 03:21 PM
Prosys OPC Test Client version 1.9.3.0. This client works fine when on the same machine as the server.
Bob
09-08-2009 01:29 PM
Hi Bob,
Are you sure all your firewalls are open?
Flash
09-08-2009 02:17 PM
The firewalls on both machines are off.
Do I need the Variable Engine service running on the remote client computer? Should I be installing anything specific to National Instruments on the remote client computer?
Thank you,
Bob
09-09-2009 08:23 AM
09-09-2009 09:10 AM
The Variable Engine can act as an OPC server and publish network/shared variables to OPC clients, but by default, it cannot communicate with arbitrary OPC servers and reflect the data to network/shared variable clients. The latter can be achieved by creating an IOServer item in Variable Manger or Distributed System Manager to subscribe to the OPC server - this is only possible if you have purchased the LabVIEW DSC Module/DSC runtime.
An alternative is to use the DataSocket library to subscribe to the OPC items. With the DataSocket library, you can connect to the OPC server without going through Network/Shared Variable Engine and without needing the DSC runtime.
09-10-2009 09:41 AM
Thank you very much for your replies.
I have resolved my issue of getting an OPC Classic Client on a remote Windows XP SP2 computer to work with an OPC Classic Server also running Windows XP SP2. It turns out I had corrupt registry entries for one or both the Dlls netshell.dll and ole32.dll. Re-registering those got everything working.
Bob
