08-05-2019 03:30 PM
Hi All,
I set up my oscilloscope for an acquisition over TCP/IP using the IVI libraries.
Scope is a Tektronix DPO7354C.
I have no problems setting up Triggers and Channels but when I get to set the acquisition I have problems
This is my call sequence:
IviScope_ConfigureAcquisitionType (scopeHandle, IVISCOPE_VAL_NORMAL); //OK
IviScope_ConfigureAcquisitionRecord (scopeHandle, 0.001, 1000, 0.0); //FAIL
IviScope_ConfigureInterpolation (scopeHandle, IVISCOPE_VAL_NO_INTERPOLATION); //FAIL
I've an error on
IviScope_ConfigureAcquisitionRecord and IviScope_ConfigureInterpolation
If I comment on these two calls everything goes well and I acquire my waveform.
Could anyone tell me how to solve?
08-08-2019 04:57 PM
Hi @Requiem_Q,
Could you please provide some further information on the errors you are receiving? What are the error codes and error messages? Screenshots would be helpful.
08-09-2019 04:26 AM
Hi @nestorl
The driver gives me no more information about these errors. (In other cases I have errors like "value not supported")
In the end I switched to low-level settings.
so I split
into
IviScope_SetAttributeViReal64 (scopeHandle, VI_NULL, IVISCOPE_ATTR_ACQUISITION_START_TIME, start_time/*0.0*/);
IviScope_SetAttributeViReal64 (scopeHandle, VI_NULL, IVISCOPE_ATTR_HORZ_TIME_PER_RECORD, time_per_record/*0.001*/);
IviScope_SetAttributeViReal64 (scopeHandle, VI_NULL, VISCOPE_ATTR_HORZ_MIN_NUM_PTS, min_num_pts/*1000*/);
IviScope_ConfigureInterpolation (scopeHandle, interp_type);
the problem occurs with the settings VISCOPE_ATTR_HORZ_MIN_NUM_PTS and IviScope_ConfigureInterpolation
It's a problem I only have with a Tektronix oscilloscope, I have no problems with another tested brand.
The values entered are supported by the oscilloscope (and in any case I also tried the default ones.
At this point I think it's a problem with the Tektronix driver
