LabWindows/CVI
Is there a way to use real time hardware (Field Point 2000 for instance ) with CVI ?
Does somebody know if there is a way to program real time NI hardware ( FP 2000 ) within labwindows CVI, the way Labview does ?
Thanks for your help.
(3,357 Views)
We do not have a real-time version of CVI, such as LabVIEW RT. Not yet anyway. CVI can build DLLs that LabVIEW RT can use, but to use our RT hardware in embedded mode on a RT OS, you must have LabVIEW RT.
Best Regards,
Chris Matthews
(3,356 Views)
Thank you Chris for your perfectly clear answer.
I think there is a real need for CVI developers to use RT stuff as we are supposed to work close ( closer than Labview programmers?? ) to the system and hardware. I understand from your answer that there could be something in the works. It would be great to have it included in version 7.
(3,356 Views)
Hello everyone,
In an attempt to try to catch everyone who might have a LabWindows/CVI and Linux or Real-Time interest, I'm going to repost this information in this thread as well. I know this thread has been going on for a few years now, but I wanted to update whoever is interested in the latest LabWindows/CVI modules that we've released to try to address your multiplatform support needs:
So we now have a Real-Time Module, which allows you to develop LabWindows/CVI apps on a Windows machine and run on a real-time PXI or PC target.
Also, to partly address the main subject of this thread, in August, we release the Run-Time Module for Linux, which similarly allows you to develop on a Windows machine as you always have with CVI, and then run your application on multiple Linux distributions.
That's a brief overview of the latest modules, but if you want more information on what hardware is supported and also a more in-depth discussion on the module, take a look at the following resources:
Real-Time Module: www.ni.com/lwcvi/realtime
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,197 Views)
