Greetings, BryanJ:
YOu can also use the Intensity Chart do do what you want. You will need to transpose your data, because the intensity is by default geared to your "Y" data. YOu will want to sumultaneously direct the Y data to both the Y and Z axis, and then map the intensity to the color you want. It's a convoluted, if perhaps overkill approach, but I've used it for years. Hope this helps!
Chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
