LabWindows/CVI
Is there a known problem with fgetpos and fsetpos in LabWindows/CVI? v6.0
I'm using fgetpos & fsetpos with LabWindows/CVI v6. The file pointer always ends up 7 bytes too early in the file. (MS Visual studio works fine with the same code) is this a known problem? If so is there a patch available?
(3,324 Views)
There is not been any problem reported with these functions. Can you post example code that illustrates the problem you are seeing?
Best Regards,
Chris Matthews
(3,324 Views)
The plot has thickened a bit:
In trying to provide a cut down version of the program to demonstrate the problem I have discovered that it does not occur on a cut down version of the data file.
The full file is 5500k bytes, but the problem occurs on reading just the first 3 lines. A test version of only the first 4 lines works fine.
I'll attach the test code (not the most beautifull) but unfortunately the data file is proprietory so I can't attach that.
Any thoughts would be welcome!
(3,324 Views)
Well, I didn't find anything wrong with your code. I tried running it on about a dozen files of various sizes, one of which was over 2Megs of text. I couldn't reproduce the problem you are seeing with any of them. I don't really know what else to look for to try and help.
Chris
(3,324 Views)
I've been doing a bit more digging and discovered that:
The data file I'm interested in , and creates a problem, terminates the lines with just 0x0a (LF).
Whereas the short test file terminates the lines with 0x0d, 0x0a (CR,LF) and is fine.
Now I would have thought in this day and age standard libraries would have been able to handle the dos/unix difference. Apparently not!
An abbreviated file of test data is attached for anyone interested. Run the test program on it and see the fgetpos problem; Remove a few lines; rerun the test program and watch the file position move.
Anyone got any suggestions, short of reformatting all current and future data files?
(3,324 Views)
