LabWindows/CVI
Is it possible to program a cRIO-9081 RT using LabWindows/CVI Real Time?
I need to offload some of my PXI DAQ to a remote device.  Currently I am using a PXI and two cDAQ chassis.  One cDAQ chassis is 10m away.  I want to replace it with something else to get away from USB because I get timeouts from time to time.  I thought I could just get a cRIO that runs LV RealTime (Pharlap?) like my PXI and then program it similarly.  The Add/Remove Software section of NI MAX for the RIO looks nothing like the PXI.  Fall back plan would be to have a LV developer do what I was going to do in CVI if it can't be done, but I'd like to do it myself if possible.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(995 Views)
Accepted by topic author DieselPower
Looks like the answer is no.  There are no cRIO systems that support both Pharlap and DAQmx.
(967 Views)
