07-15-2024 11:53 AM
I have been developing in LabWindows/CVI.
I did some code enhancements / improvements for an old project which uses the FT4222 library files:
ftd2xx.lib (64-bit)
LibFT4222-64.lib (64-bit)
I did not originate this old project which was started before I worked with this company.
Now, I have started a new LabWindows/CVI project from scratch where I also need to use those library files.
I did an explore directory for those files to find their location in the old project.
Without doing any installation, I simply copied over the whole folder to my own new project folder.
Then I added those "existing" library files to my project inside LabWindows/CVI.
Please see attached screenshot of the Library Files list on project explorer. Notice how those particular library files are greyed-out?
This is not the case for the old project.
What have I missed or incorrectly done?
Please advise.
Thanks for the help.
MI
07-15-2024 01:18 PM - edited 07-15-2024 01:20 PM
Maybe your current build configuration is for 32 bits and those are 64 bit LIB files?
07-15-2024 02:44 PM
Hi Eren,
You are right.
My build configuration was set to 32-bit. I switched to 64-bit and they are no longer greyed-out.
Many thanks for this help.
MI
